If 4 byte AS numbers are used, RTs should be manually created.
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-36 configure vr VR-Default add ports 1-36 configure vlan default delete ports 1,4-5,7,16,19,21 enable jumbo-frame ports all create vlan "isc" configure vlan isc tag 4000 create vlan "loop" enable loopback-mode vlan loop create vlan "mlagvtep" enable loopback-mode vlan mlagvtep create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "trunk1_2" configure vlan trunk1_2 tag 4001 create vlan "trunk1_3" create vlan "trunk1_4" create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 1 auto off speed 10000 duplex full configure ports 2 auto off speed 10000 duplex full configure ports 3 auto off speed 10000 duplex full configure ports 4 auto off speed 10000 duplex full configure ports 5 auto off speed 10000 duplex full configure ports 6 auto off speed 10000 duplex full configure ports 7 auto off speed 10000 duplex full configure ports 8 auto off speed 10000 duplex full configure ports 9 auto off speed 10000 duplex full configure ports 10 auto off speed 10000 duplex full configure ports 11 auto off speed 10000 duplex full configure ports 12 auto off speed 10000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 10000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto off speed 10000 duplex full configure ports 18 auto off speed 10000 duplex full configure ports 19 auto off speed 10000 duplex full configure ports 20 auto off speed 10000 duplex full configure ports 21 auto off speed 10000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full enable sharing 1 grouping 1 algorithm address-based L2 lacp configure vlan Default add ports 2-3,6,8-15,17-18,20,22-36 untagged configure vlan isc add ports 21 tagged configure vlan tenant add ports 1,16,21 tagged configure vlan trunk1_2 add ports 21 tagged configure vlan trunk1_3 add ports 5 untagged configure vlan trunk1_4 add ports 7 untagged configure vlan untagtenant add ports 1,16,21 untagged configure vlan isc ipaddress 172.16.1.0 255.255.255.254 configure vlan loop ipaddress 1.1.1.1 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.27 255.255.255.0 configure vlan mlagvtep ipaddress 1.1.1.200 255.255.255.255 enable ipforwarding vlan mlagvtep configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan trunk1_2 ipaddress 192.168.5.0 255.255.255.254 enable ipforwarding vlan trunk1_2 configure vlan trunk1_3 ipaddress 192.168.1.0 255.255.255.254 enable ipforwarding vlan trunk1_3 configure vlan trunk1_4 ipaddress 192.168.2.0 255.255.255.254 enable ipforwarding vlan trunk1_4 configure vlan untagtenant ipaddress 20.1.100.100 255.255.255.0 enable ipforwarding vlan untagtenant # # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module vsm configuration. # create mlag peer "leaf2" configure mlag peer "leaf2" ipaddress 172.16.1.1 vr VR-Default configure mlag peer "leaf2" lacp-mac 00:00:de:ad:be:ef enable mlag port 1 peer "leaf2" id 1 # # Module ospf configuration. # configure ospf routerid 1.1.1.1 enable ospf configure ospf add vlan loop area 0.0.0.0 configure ospf vlan loop priority 0 configure ospf add vlan mlagvtep area 0.0.0.0 configure ospf add vlan trunk1_2 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk1_3 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk1_4 area 0.0.0.0 link-type point-to-point # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 1.1.1.1 configure bgp maximum-paths 2 configure bgp add network 1.1.1.1/32 configure bgp add network 1.1.1.200/32 create bgp neighbor 2.2.2.2 remote-AS-number 10000 configure bgp neighbor 2.2.2.2 source-interface ipaddress 1.1.1.1 enable bgp neighbor 2.2.2.2 create bgp neighbor 3.3.3.100 remote-AS-number 10000 configure bgp neighbor 3.3.3.100 source-interface ipaddress 1.1.1.1 enable bgp neighbor 3.3.3.100 create bgp neighbor 4.4.4.4 remote-AS-number 10000 configure bgp neighbor 4.4.4.4 source-interface ipaddress 1.1.1.1 enable bgp neighbor 4.4.4.4 enable bgp neighbor 2.2.2.2 capability l2vpn-EVPN enable bgp neighbor 3.3.3.100 capability l2vpn-EVPN enable bgp neighbor 4.4.4.4 capability l2vpn-EVPN enable bgp export direct address-family ipv4-unicast enable bgp # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 1.1.1.200 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-72 configure vr VR-Default add ports 1-72 configure vlan default delete ports 1-72 enable jumbo-frame ports all create vlan "isc" configure vlan isc tag 4000 create vlan "loop" enable loopback-mode vlan loop create vlan "loop2" enable loopback-mode vlan loop2 create vlan "mlagvtep" enable loopback-mode vlan mlagvtep create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "trunk1_2" configure vlan trunk1_2 tag 4001 create vlan "trunk2_3" create vlan "trunk2_4" create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full enable sharing 53 grouping 53-56 algorithm address-based L2 lacp configure vlan isc add ports 66 tagged configure vlan tenant add ports 4-5,53,66 tagged configure vlan trunk1_2 add ports 66 tagged configure vlan trunk2_3 add ports 57 untagged configure vlan trunk2_4 add ports 49 untagged configure vlan untagtenant add ports 4-5,53,66 untagged configure vlan isc ipaddress 172.16.1.1 255.255.255.254 configure vlan loop ipaddress 2.2.2.2 255.255.255.255 enable ipforwarding vlan loop configure vlan loop2 ipaddress 2.2.2.100 255.255.255.255 enable ipforwarding vlan loop2 configure vlan Mgmt ipaddress 10.127.16.19 255.255.255.0 configure vlan mlagvtep ipaddress 1.1.1.200 255.0.0.0 enable ipforwarding vlan mlagvtep configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan trunk1_2 ipaddress 192.168.5.1 255.255.255.254 enable ipforwarding vlan trunk1_2 configure vlan trunk2_3 ipaddress 192.168.3.0 255.255.255.254 enable ipforwarding vlan trunk2_3 configure vlan trunk2_4 ipaddress 192.168.4.0 255.255.255.254 enable ipforwarding vlan trunk2_4 configure vlan untagtenant ipaddress 20.1.100.100 255.255.255.0 enable ipforwarding vlan untagtenant # # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 1.1.1.200 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 2.2.2.2 configure bgp maximum-paths 2 configure bgp add network 1.1.1.200/32 configure bgp add network 2.2.2.2/32 create bgp neighbor 1.1.1.1 remote-AS-number 10000 configure bgp neighbor 1.1.1.1 source-interface ipaddress 2.2.2.2 enable bgp neighbor 1.1.1.1 create bgp neighbor 3.3.3.100 remote-AS-number 10000 configure bgp neighbor 3.3.3.100 source-interface ipaddress 2.2.2.2 enable bgp neighbor 3.3.3.100 create bgp neighbor 4.4.4.4 remote-AS-number 10000 configure bgp neighbor 4.4.4.4 source-interface ipaddress 2.2.2.2 enable bgp neighbor 4.4.4.4 enable bgp neighbor 1.1.1.1 capability l2vpn-EVPN enable bgp neighbor 3.3.3.100 capability l2vpn-EVPN enable bgp neighbor 4.4.4.4 capability l2vpn-EVPN enable bgp export direct address-family ipv4-unicast enable bgp # # Module ospf configuration. # configure ospf routerid 2.2.2.2 enable ospf configure ospf add vlan loop area 0.0.0.0 configure ospf add vlan mlagvtep area 0.0.0.0 configure ospf add vlan trunk1_2 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk2_3 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk2_4 area 0.0.0.0 link-type point-to-point # # Module vrrp configuration. # create vrrp vlan tenant vrid 1 configure vrrp vlan tenant vrid 1 priority 255 create vrrp vlan untagtenant vrid 1 configure vrrp vlan untagtenant vrid 1 priority 255 configure vrrp vlan tenant vrid 1 add 10.1.100.100 configure vrrp vlan untagtenant vrid 1 add 20.1.100.100 enable vrrp vlan tenant vrid 1 enable vrrp vlan untagtenant vrid 1 # # Module vsm configuration. # create mlag peer "leaf1" configure mlag peer "leaf1" ipaddress 172.16.1.0 vr VR-Default configure mlag peer "leaf1" lacp-mac 00:00:de:ad:be:ef enable mlag port 53 peer "leaf1" id 1
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-56 configure vr VR-Default add ports 1-56 configure vlan default delete ports 1,50-51 enable jumbo-frame ports all create vlan "leaf3_trunk1" create vlan "leaf3_trunk2" create vlan "loop" enable loopback-mode vlan loop create vlan "tenant" configure vlan tenant tag 10 configure vlan tenant suppress arp-only create vlan "untagtenant" configure vlan untagtenant suppress arp-only configure ports 49 auto off speed 10000 duplex full configure ports 50 auto off speed 10000 duplex full configure ports 51 auto off speed 10000 duplex full configure ports 52 auto off speed 10000 duplex full configure ports 54 auto off speed 10000 duplex full configure ports 55 auto off speed 10000 duplex full configure ports 56 auto off speed 10000 duplex full configure vlan Default add ports 2-49,52-56 untagged configure vlan leaf3_trunk1 add ports 51 untagged configure vlan leaf3_trunk2 add ports 50 untagged configure vlan tenant add ports 1 tagged configure vlan untagtenant add ports 1 untagged configure vlan leaf3_trunk1 ipaddress 192.168.6.0 255.255.255.254 enable ipforwarding vlan leaf3_trunk1 configure vlan leaf3_trunk2 ipaddress 192.168.7.0 255.255.255.254 enable ipforwarding vlan leaf3_trunk2 configure vlan loop ipaddress 5.5.5.5 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.17 255.255.255.0 configure vlan tenant ipaddress 10.1.100.100 255.255.255.0 enable ipforwarding vlan tenant configure vlan untagtenant ipaddress # Module mcmgr configuration. # disable igmp snooping vlan "tenant" disable igmp snooping vlan "untagtenant" # # Module otm configuration. # configure virtual-network local-endpoint ipaddress 5.5.5.5 vr "VR-Default" create virtual-network "vni1" flooding standard configure virtual-network "vni1" VXLAN vni 100 configure virtual-network "vni1" add vlan tenant create virtual-network "vni2" flooding standard configure virtual-network "vni2" VXLAN vni 200 configure virtual-network "vni2" add vlan untagtenant # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 5.5.5.5 configure bgp maximum-paths 2 configure bgp restart both configure bgp add network 5.5.5.5/32 create bgp neighbor 3.3.3.100 remote-AS-number 10000 configure bgp neighbor 3.3.3.100 source-interface ipaddress 5.5.5.5 enable bgp neighbor 3.3.3.100 create bgp neighbor 4.4.4.4 remote-AS-number 10000 configure bgp neighbor 4.4.4.4 source-interface ipaddress 5.5.5.5 enable bgp neighbor 4.4.4.4 enable bgp neighbor 3.3.3.100 capability l2vpn-EVPN enable bgp neighbor 4.4.4.4 capability l2vpn-EVPN enable bgp # # Module ospf configuration. # enable ospf configure ospf add vlan leaf1_trunk2 area 0.0.0.0 link-type point-to-point configure ospf add vlan leaf3_trunk2 area 0.0.0.0 link-type point-to-point configure ospf add vlan loop area 0.0.0.0 link-type point-to-point # # Module vrrp configuration. # create vrrp vlan tenant vrid 1 configure vrrp vlan tenant vrid 1 priority 255 create vrrp vlan untagtenant vrid 1 configure vrrp vlan untagtenant vrid 1 priority 255 configure vrrp vlan tenant vrid 1 add 10.1.100.100 configure vrrp vlan untagtenant vrid 1 add 20.1.100.100 enable vrrp vlan tenant vrid 1 enable vrrp vlan untagtenant vrid 1
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-128 configure vr VR-Default add ports 1-128 configure vlan default delete ports 33,57,89,105 enable jumbo-frame ports all create vlan "leaf3_trunk1" create vlan "loop" enable loopback-mode vlan loop create vlan "routed" configure vlan routed tag 4030 create vlan "trunk1_3" create vlan "trunk2_3" configure vlan Default add ports 1-32,34-56,58-88,90-104,106-128 untagged configure vlan leaf3_trunk1 add ports 89 untagged configure vlan routed add ports 33 tagged configure vlan trunk1_3 add ports 57 untagged configure vlan trunk2_3 add ports 105 untagged configure vlan leaf3_trunk1 ipaddress 192.168.6.1 255.255.255.254 enable ipforwarding vlan leaf3_trunk1 configure vlan loop ipaddress 3.3.3.100 255.0.0.0 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.16.24 255.255.255.0 configure vlan routed ipaddress 172.16.1.1 255.255.255.0 enable ipforwarding vlan routed configure vlan trunk1_3 ipaddress 192.168.1.1 255.255.255.254 enable ipforwarding vlan trunk1_3 configure vlan trunk2_3 ipaddress 192.168.3.1 255.255.255.254 enable ipforwarding vlan trunk2_3 # # # Module ospf configuration. # enable ospf configure ospf add vlan leaf3_trunk1 area 0.0.0.0 link-type point-to-point configure ospf add vlan loop area 0.0.0.0 link-type point-to-point configure ospf add vlan routed area 0.0.0.0 configure ospf add vlan trunk1_3 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk2_3 area 0.0.0.0 link-type point-to-point # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 3.3.3.3 configure bgp maximum-paths 2 configure bgp add network 3.3.3.100/32 create bgp neighbor 1.1.1.1 remote-AS-number 10000 configure bgp neighbor 1.1.1.1 route-reflector-client configure bgp neighbor 1.1.1.1 source-interface ipaddress 3.3.3.100 enable bgp neighbor 1.1.1.1 create bgp neighbor 2.2.2.2 remote-AS-number 10000 configure bgp neighbor 2.2.2.2 route-reflector-client configure bgp neighbor 2.2.2.2 source-interface ipaddress 3.3.3.100 enable bgp neighbor 2.2.2.2 create bgp neighbor 5.5.5.5 remote-AS-number 10000 configure bgp neighbor 5.5.5.5 route-reflector-client configure bgp neighbor 5.5.5.5 source-interface ipaddress 3.3.3.100 enable bgp neighbor 5.5.5.5 enable bgp neighbor 1.1.1.1 capability l2vpn-EVPN enable bgp neighbor 2.2.2.2 capability l2vpn-EVPN enable bgp neighbor 5.5.5.5 capability l2vpn-EVPN enable bgp export ospf-extern1 address-family ipv4-unicast enable bgp export ospf-extern2 address-family ipv4-unicast enable bgp export ospf-inter address-family ipv4-unicast enable bgp export ospf-intra address-family ipv4-unicast enable bgp
# # Module vlan configuration. # configure vlan default delete ports all configure vr VR-Default delete ports 1-64 configure vr VR-Default add ports 1-64 configure vlan default delete ports 25,27,49 create vlan "leaf3_trunk2" create vlan "loop" enable loopback-mode vlan loop create vlan "trunk1_4" create vlan "trunk2_4" configure ports 1 auto off speed 10000 duplex full configure ports 2 auto off speed 10000 duplex full configure ports 3 auto off speed 10000 duplex full configure ports 4 auto off speed 10000 duplex full configure ports 5 auto off speed 10000 duplex full configure ports 6 auto off speed 10000 duplex full configure ports 7 auto off speed 10000 duplex full configure ports 8 auto off speed 10000 duplex full configure ports 9 auto off speed 10000 duplex full configure ports 10 auto off speed 10000 duplex full configure ports 11 auto off speed 10000 duplex full configure ports 12 auto off speed 10000 duplex full configure ports 13 auto off speed 10000 duplex full configure ports 14 auto off speed 10000 duplex full configure ports 15 auto off speed 10000 duplex full configure ports 16 auto off speed 10000 duplex full configure ports 17 auto off speed 10000 duplex full configure ports 18 auto off speed 10000 duplex full configure ports 19 auto off speed 10000 duplex full configure ports 20 auto off speed 10000 duplex full configure ports 21 auto off speed 10000 duplex full configure ports 22 auto off speed 10000 duplex full configure ports 23 auto off speed 10000 duplex full configure ports 24 auto off speed 10000 duplex full configure ports 25 auto off speed 10000 duplex full configure ports 26 auto off speed 10000 duplex full configure ports 27 auto off speed 10000 duplex full configure ports 28 auto off speed 10000 duplex full configure ports 29 auto off speed 10000 duplex full configure ports 30 auto off speed 10000 duplex full configure ports 31 auto off speed 10000 duplex full configure ports 32 auto off speed 10000 duplex full configure ports 33 auto off speed 10000 duplex full configure ports 34 auto off speed 10000 duplex full configure ports 35 auto off speed 10000 duplex full configure ports 36 auto off speed 10000 duplex full configure ports 37 auto off speed 10000 duplex full configure ports 38 auto off speed 10000 duplex full configure ports 39 auto off speed 10000 duplex full configure ports 40 auto off speed 10000 duplex full configure ports 41 auto off speed 10000 duplex full configure ports 42 auto off speed 10000 duplex full configure ports 43 auto off speed 10000 duplex full configure ports 44 auto off speed 10000 duplex full configure ports 45 auto off speed 10000 duplex full configure ports 46 auto off speed 10000 duplex full configure ports 47 auto off speed 10000 duplex full configure ports 48 auto off speed 10000 duplex full configure vlan Default add ports 1-24,26,28-48,50-64 untagged configure vlan leaf3_trunk2 add ports 25 untagged configure vlan trunk1_4 add ports 27 untagged configure vlan trunk2_4 add ports 49 untagged configure vlan leaf3_trunk2 ipaddress 192.168.7.1 255.255.255.254 enable ipforwarding vlan leaf3_trunk2 configure vlan loop ipaddress 4.4.4.4 255.255.255.255 enable ipforwarding vlan loop configure vlan Mgmt ipaddress 10.127.13.10 255.255.255.0 configure vlan trunk1_4 ipaddress 192.168.2.1 255.255.255.254 enable ipforwarding vlan trunk1_4 configure vlan trunk2_4 ipaddress 192.168.4.1 255.255.255.254 enable ipforwarding vlan trunk2_4 # # Module bgp configuration. # configure bgp AS-number 10000 configure bgp routerid 4.4.4.4 configure bgp maximum-paths 2 configure bgp add network 3.3.3.100/32 configure bgp add network 4.4.4.4/32 create bgp neighbor 1.1.1.1 remote-AS-number 10000 configure bgp neighbor 1.1.1.1 route-reflector-client configure bgp neighbor 1.1.1.1 source-interface ipaddress 4.4.4.4 enable bgp neighbor 1.1.1.1 create bgp neighbor 2.2.2.2 remote-AS-number 10000 configure bgp neighbor 2.2.2.2 route-reflector-client configure bgp neighbor 2.2.2.2 source-interface ipaddress 4.4.4.4 enable bgp neighbor 2.2.2.2 create bgp neighbor 5.5.5.5 remote-AS-number 10000 configure bgp neighbor 5.5.5.5 route-reflector-client configure bgp neighbor 5.5.5.5 source-interface ipaddress 4.4.4.4 enable bgp neighbor 5.5.5.5 enable bgp neighbor 1.1.1.1 capability l2vpn-EVPN enable bgp neighbor 2.2.2.2 capability l2vpn-EVPN enable bgp neighbor 5.5.5.5 capability l2vpn-EVPN enable bgp # # Module ospf configuration. # enable ospf configure ospf add vlan leaf3_trunk2 area 0.0.0.0 link-type point-to-point configure ospf add vlan loop area 0.0.0.0 configure ospf add vlan trunk1_4 area 0.0.0.0 link-type point-to-point configure ospf add vlan trunk2_4 area 0.0.0.0 link-type point-to-point
Leaf1.1 # show ospf neighbor
Neighbor ID Pri State Up/Dead Time Address Interface
BFD Session State
2.2.2.2 1 FULL /DROTHER 00:00:59:02/00:00:00:08 192.168.5.1 trunk1_2
None
192.168.6.1 1 FULL /DROTHER 00:00:59:02/00:00:00:02 192.168.1.1 trunk1_3
None
192.168.7.1 1 FULL /DROTHER 00:00:59:02/00:00:00:00 192.168.2.1 trunk1_4
None
Total number of neighbors: 3 (All neighbors in Full state)
Leaf2.15 # show ospf neighbor
BFD Session State
1.1.1.1 1 FULL /DROTHER 00:00:59:22/00:00:00:02 192.168.5.0 trunk1_2
None
192.168.6.1 1 FULL /DROTHER 00:00:59:37/00:00:00:05 192.168.3.1 trunk2_3
None
192.168.7.1 1 FULL /DROTHER 00:00:59:37/00:00:00:06 192.168.4.1 trunk2_4
None
Leaf3.12 # show ospf neighbor
BFD Session State
192.168.6.1 1 FULL /DROTHER 00:00:02:00/00:00:00:01 192.168.6.1 leaf3_tru
None
192.168.7.1 1 FULL /DROTHER 00:01:33:25/00:00:00:01 192.168.7.1 leaf3_tru
None
Total number of neighbors: 2 (All neighbors in Full state)
Spine1.1 # show ospf neighbor
BFD Session State
192.168.7.0 1 FULL /DROTHER 00:00:22:40/00:00:00:01 192.168.6.0 leaf3_tru
None
1.1.1.1 1 FULL /DROTHER 00:01:23:37/00:00:00:07 192.168.1.0 trunk1_3
None
2.2.2.2 1 FULL /DROTHER 00:01:23:53/00:00:00:03 192.168.3.0 trunk2_3
None
Spine2.1 # show ospf neighbor
BFD Session State
192.168.7.0 1 FULL /DROTHER 00:01:54:24/00:00:00:04 192.168.7.0 leaf3_tru
None
1.1.1.1 1 FULL /DROTHER 00:01:23:55/00:00:00:05 192.168.2.0 trunk1_4
None
2.2.2.2 1 FULL /DROTHER 00:01:24:10/00:00:00:10 192.168.4.0 trunk2_4
None
Leaf1.1 # show bgp neighbor
Peer AS Weight State InMsgs OutMsgs(InQ) Up/Down
Ie-- 2.2.2.2 10000 1 ESTABLISHED 150 149 (0 ) 0:1:59:37
Ie-- 3.3.3.100 10000 1 ESTABLISHED 182 149 (0 ) 0:1:59:37
Ie-- 4.4.4.4 10000 1 ESTABLISHED 191 158 (0 ) 0:0:17:47
Flags: (d) disabled, (e) enabled, (E) external peer, (I) internal peer
(m) EBGP multihop, (r) route reflector client
BGP Peer Statistics
Total Peers : 3
EBGP Peers : 0 IBGP Peers : 3
RR Client : 0 EBGP Multihop : 0
Enabled : 3 Disabled : 0
(Software Update Required) Leaf2.16 # show bgp neighbor
Ie-- 1.1.1.1 10000 1 ESTABLISHED 271 288 (0 ) 0:1:59:59
Ie-- 3.3.3.100 10000 1 ESTABLISHED 556 415 (0 ) 0:2:52:09
Ie-- 4.4.4.4 10000 1 ESTABLISHED 1585 1509 (0 ) 0:20:58:35
BGP Peer Statistics
Total Peers : 3
Leaf3.1 # show bgp neighbor
Ie-- 3.3.3.100 10000 1 ESTABLISHED 171 144 (0 ) 0:1:55:46
Ie-- 4.4.4.4 10000 1 ESTABLISHED 175 144 (0 ) 0:1:55:37
BGP Peer Statistics
Total Peers : 2
EBGP Peers : 0 IBGP Peers : 2
Enabled : 2 Disabled : 0
Spine1.2 # show bgp neighbor
Ier- 1.1.1.1 10000 1 ESTABLISHED 150 183 (0 ) 0:2:00:42
Ier- 2.2.2.2 10000 1 ESTABLISHED 222 265 (0 ) 0:2:52:53
Ier- 5.5.5.5 10000 1 ESTABLISHED 184 249 (0 ) 0:1:56:07
BGP Peer Statistics
Total Peers : 3
RR Client : 3 EBGP Multihop : 0
Spine2.2 # show bgp neighbor
Ier- 1.1.1.1 10000 1 ESTABLISHED 276 390 (0 ) 0:0:19:14
Ier- 2.2.2.2 10000 1 ESTABLISHED 1501 1606 (0 ) 0:20:59:40
Ier- 5.5.5.5 10000 1 ESTABLISHED 1465 1595 (0 ) 0:1:56:20
BGP Peer Statistics
Total Peers : 3
Leaf1.2 # show bgp EVPN evi Flgs EVI-Idx Name VNI Local VTEP RD Import RT Export RT ---- ------- -------------------- ---------- --------------- -------------------- -------------------- -------------------- * 10 100 1.1.1.200 1.1.1.200:10 * 10000:10 10000:10 * 10000:268435556 10000:268435556 * 10000:1073741834 10000:1073741834 * 4087 200 1.1.1.200 1.1.1.200:4087 * 10000:4087 10000:4087 * 10000:268435656 10000:268435656 * 10000:1073745911 10000:1073745911 Flags: (*) Entry is active, (S) Entry is statically configured. RD: Route Distinguisher RT: Route Target Some static entries may have multiple Route Target sets. These are listed in rows immediately following the initial row for the EVI-Idx. EVIs Displayed - Total: 2 Static: 0 Dyn: 2 Leaf2.17 # show bgp EVPN evi Flgs EVI-Idx Name VNI Local VTEP RD Import RT Export RT ---- ------- -------------------- ---------- --------------- -------------------- -------------------- -------------------- * 10 100 1.1.1.200 1.1.1.200:10 * 10000:10 10000:10 * 10000:268435556 10000:268435556 * 10000:1073741834 10000:1073741834 * 4088 200 1.1.1.200 1.1.1.200:4088 * 10000:4088 10000:4088 * 10000:268435656 10000:268435656 * 10000:1073745912 10000:1073745912 Flags: (*) Entry is active, (S) Entry is statically configured. RD: Route Distinguisher RT: Route Target Some static entries may have multiple Route Target sets. These are listed in rows immediately following the initial row for the EVI-Idx. EVIs Displayed - Total: 2 Static: 0 Dyn: 2 Leaf3.2 # show bgp EVPN evi Flgs EVI-Idx Name VNI Local VTEP RD Import RT Export RT ---- ------- -------------------- ---------- --------------- -------------------- -------------------- -------------------- * 10 100 5.5.5.5 5.5.5.5:10 * 10000:10 10000:10 * 10000:268435556 10000:268435556 * 10000:1073741834 10000:1073741834 * 4090 200 5.5.5.5 5.5.5.5:4090 * 10000:4090 10000:4090 * 10000:268435656 10000:268435656 * 10000:1073745914 10000:1073745914 Flags: (*) Entry is active, (S) Entry is statically configured. RD: Route Distinguisher RT: Route Target Some static entries may have multiple Route Target sets. These are listed in rows immediately following the initial row for the EVI-Idx. EVIs Displayed - Total: 2 Static: 0 Dyn: 2 Spine1.3 # show bgp EVPN evi Flgs EVI-Idx Name VNI Local VTEP RD Import RT Export RT ---- ------- -------------------- ---------- --------------- -------------------- -------------------- -------------------- * 10 100 3.3.3.100 3.3.3.100:10 * 10000:10 10000:10 * 10000:268435556 10000:268435556 * 10000:1073741834 10000:1073741834 * 4091 200 3.3.3.100 3.3.3.100:4091 * 10000:4091 10000:4091 * 10000:268435656 10000:268435656 * 10000:1073745915 10000:1073745915 Flags: (*) Entry is active, (S) Entry is statically configured. RD: Route Distinguisher RT: Route Target Some static entries may have multiple Route Target sets. These are listed in rows immediately following the initial row for the EVI-Idx. EVIs Displayed - Total: 2 Static: 0 Dyn: 2
Leaf1.4 # show bgp routes l2vpn-EVPN inclusive-multicast all
Routes:
Originating IP Tunnel ID VNI Peer Next-Hop AS-Path
? RD: 1.1.1.200:10 Ethernet Tag: 0 Tunnel Type: 6
1.1.1.200 1.1.1.200 100 2.2.2.2 1.1.1.200
? RD: 1.1.1.200:4088 Ethernet Tag: 0 Tunnel Type: 6
1.1.1.200 1.1.1.200 200 2.2.2.2 1.1.1.200
1.1.1.200 1.1.1.200 200 3.3.3.100 1.1.1.200
1.1.1.200 1.1.1.200 200 4.4.4.4 1.1.1.200
? RD: 3.3.3.100:10 Ethernet Tag: 0 Tunnel Type: 6
3.3.3.100 3.3.3.100 100 3.3.3.100 3.3.3.100
? RD: 3.3.3.100:4091 Ethernet Tag: 0 Tunnel Type: 6
3.3.3.100 3.3.3.100 200 3.3.3.100 3.3.3.100
? RD: 5.5.5.5:10 Ethernet Tag: 0 Tunnel Type: 6
5.5.5.5 5.5.5.5 100 3.3.3.100 5.5.5.5
5.5.5.5 5.5.5.5 100 4.4.4.4 5.5.5.5
? RD: 5.5.5.5:4090 Ethernet Tag: 0 Tunnel Type: 6
5.5.5.5 5.5.5.5 200 3.3.3.100 5.5.5.5
5.5.5.5 5.5.5.5 200 4.4.4.4 5.5.5.5
Flags: (*) Preferred BGP route, (>) Active, (d) Suppressed, (h) History
(s) Stale, (m) Multipath, (u) Unfeasible
Origin: (?) Incomplete, (e) EGP, (i) IGP
BGP Route Statistics EVPN route type 3
Total Rxed Routes : 10
Feasible Routes : 10
Active Routes : 0
Rejected Routes : 0
Unfeasible Routes : 0
Route Statistics on Session Type
Routes from Int Peer: 10
Routes from Ext Peer: 0
Leaf2.18 # show bgp routes l2vpn-EVPN inclusive-multicast all
Routes:
1.1.1.200 1.1.1.200 100 1.1.1.1 1.1.1.200
1.1.1.200 1.1.1.200 100 3.3.3.100 1.1.1.200
1.1.1.200 1.1.1.200 100 4.4.4.4 1.1.1.200
? RD: 1.1.1.200:4087 Ethernet Tag: 0 Tunnel Type: 6
1.1.1.200 1.1.1.200 200 1.1.1.1 1.1.1.200
Total Rxed Routes : 12
Feasible Routes : 12
Active Routes : 0
Rejected Routes : 0
Routes from Int Peer: 12
Leaf3.12 # show bgp routes l2vpn-EVPN inclusive-multicast all
Routes:
Total Rxed Routes : 8
Feasible Routes : 8
Active Routes : 0
Rejected Routes : 0
Routes from Int Peer: 8
Routes:
5.5.5.5 5.5.5.5 100 5.5.5.5 5.5.5.5
5.5.5.5 5.5.5.5 200 5.5.5.5 5.5.5.5
Total Rxed Routes : 6
Feasible Routes : 6
Active Routes : 0
Rejected Routes : 0
Routes from Int Peer: 6
Leaf1.4 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 00:00:0b:cb:21:a4 100 Yes L 10 00:00:0c:14:88:4b 100 Yes L 10 00:00:0c:34:c1:ed 100 Yes L 10 00:04:96:9d:42:32 100 Yes L 10 00:04:96:a3:fb:b0 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4087 00:00:00:1c:7e:5f 200 Yes R 4087 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4087 00:00:04:d6:4d:6e 200 Yes L 4087 00:00:04:d6:4d:6f 200 Yes L 4087 00:04:96:9d:42:32 200 Yes L 4087 00:04:96:a3:fb:b0 200 Yes R 4087 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 14 Leaf2.19 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 00:00:0b:cb:21:a4 100 Yes L 10 00:00:0c:14:88:4b 100 Yes L 10 00:00:0c:34:c1:ed 100 Yes L 10 00:04:96:9d:42:32 100 Yes L 10 00:04:96:a3:fb:b0 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4088 00:00:00:1c:7e:5f 200 Yes R 4088 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4088 00:00:04:d6:4d:6e 200 Yes L 4088 00:00:04:d6:4d:6f 200 Yes L 4088 00:04:96:9d:42:32 200 Yes L 4088 00:04:96:a3:fb:b0 200 Yes R 4088 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 14 Leaf3.21 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- R 10 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 00:04:96:a3:fb:b0 1.1.1.200 100 Yes L 10 00:11:88:ff:04:74 100 Yes R 4090 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4090 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4090 00:04:96:a3:fb:b0 1.1.1.200 200 Yes L 4090 00:11:88:ff:04:74 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 19 Spine1.37 # show bgp EVPN mac Src EVI-Idx MAC BGP Next Hop VNI ESI ESI-Port In Use Sequence --- ------- ----------------- --------------- ---------- ------------------------------ ---------- ------ -------- L 10 00:00:00:1c:7e:60 100 Yes R 10 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 00:04:96:a3:fb:b0 1.1.1.200 100 Yes R 10 00:11:88:ff:04:74 5.5.5.5 100 Yes R 4091 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4091 00:00:00:1c:7e:5f 1.1.1.200 200 Yes L 4091 00:00:00:1c:7e:61 200 Yes R 4091 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in MAC forwarding database. Total MAC/IP entries displayed: 19
Leaf1.6 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 10.1.100.1 00:00:0b:cb:21:a4 100 Yes L 10 10.1.100.2 00:00:0c:34:c1:ed 100 Yes L 10 10.1.100.100 00:04:96:a3:fb:b0 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes R 4087 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4087 20.1.100.1 00:00:04:d6:4d:6e 200 Yes L 4087 20.1.100.2 00:00:04:d6:4d:6f 200 Yes L 4087 20.1.100.100 00:04:96:a3:fb:b0 200 Yes R 4087 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 10 Leaf2.21 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes L 10 10.1.100.5 00:00:0c:14:88:4b 100 Yes L 10 10.1.100.2 00:00:0c:34:c1:ed 100 Yes L 10 10.1.100.100 00:04:96:9d:42:32 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes L 4088 20.1.100.5 00:00:00:1c:7e:5f 200 Yes R 4088 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes L 4088 20.1.100.2 00:00:04:d6:4d:6f 200 Yes L 4088 20.1.100.100 00:04:96:9d:42:32 200 Yes R 4088 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache. Total MAC/IP entries displayed: 10 Leaf3.22 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ R 10 10.1.100.3 00:00:00:1c:7e:60 3.3.3.100 100 Yes R 10 10.1.100.1 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 10.1.100.5 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 10.1.100.2 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 100 Yes L 10 10.1.100.100 00:11:88:ff:04:74 100 Yes R 4090 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes R 4090 20.1.100.3 00:00:00:1c:7e:61 3.3.3.100 200 Yes R 4090 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4090 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4090 20.1.100.100 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4090 20.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 200 Yes L 4090 20.1.100.100 00:11:88:ff:04:74 200 Yes Spine1.38 # show bgp EVPN ipv4 Src EVI-Idx Destination MAC BGP Next Hop VNI ESI ESI-Port In Use --- ------- --------------- ----------------- --------------- ---------- ------------------------------ ---------- ------ L 10 10.1.100.3 00:00:00:1c:7e:60 100 Yes R 10 10.1.100.1 00:00:0b:cb:21:a4 1.1.1.200 100 Yes R 10 10.1.100.5 00:00:0c:14:88:4b 1.1.1.200 100 Yes R 10 10.1.100.2 00:00:0c:34:c1:ed 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:9d:42:32 1.1.1.200 100 Yes R 10 10.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 100 Yes R 10 10.1.100.100 00:11:88:ff:04:74 5.5.5.5 100 Yes R 4091 20.1.100.5 00:00:00:1c:7e:5f 1.1.1.200 200 Yes L 4091 20.1.100.3 00:00:00:1c:7e:61 200 Yes R 4091 20.1.100.1 00:00:04:d6:4d:6e 1.1.1.200 200 Yes R 4091 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 20.1.100.2 00:00:04:d6:4d:6f 1.1.1.200 200 Yes R 4091 20.1.100.100 00:04:96:9d:42:32 1.1.1.200 200 Yes R 4091 20.1.100.100 00:04:96:a3:fb:b0 1.1.1.200 200 Yes R 4091 20.1.100.100 00:11:88:ff:04:74 5.5.5.5 200 Yes Src: (L) Local, (R) Remote In Use: Yes/No - Indicates if entry is installed in IP ARP cache.
Leaf1.8 # show iparp
VR Destination Mac Age Static VLAN VID Port
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 7 NO tenant 10 16
VR-Default 10.1.100.2 00:00:0c:34:c1:ed 7 NO tenant 10 21
VR-Default 10.1.100.3 00:00:00:1c:7e:60 0 YES tenant 10 VR-Default:3.3.3.100
VR-Default 10.1.100.5 00:00:0c:14:88:4b 0 NO tenant 10 1
VR-Default 10.1.100.6 00:00:00:47:ce:72 0 YES tenant 10 VR-Default:5.5.5.5
VR-Default 192.168.1.1 00:04:96:9c:2d:24 20 NO trunk1_3 4089 5
VR-Default 192.168.2.1 00:04:96:9b:b7:c9 8 NO trunk1_4 4088 7
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 7 NO untagtenant 4087 16
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 7 NO untagtenant 4087 21
VR-Default 20.1.100.3 00:00:00:1c:7e:61 0 YES untagtenant 4087 VR-Default:3.3.3.100
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 0 NO untagtenant 4087 1
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 YES untagtenant 4087 VR-Default:5.5.5.5
VR-Default 192.168.5.1 00:04:96:9d:42:32 20 NO trunk1_2 4001 21
VR-Default 172.16.1.1 00:04:96:9d:42:32 20 NO isc 4000 21
Dynamic Entries : 10 Static Entries : 4
Pending Entries : 0
ARP address check: Enabled ARP refresh : Enabled
Timeout : 20 minutes ARP Sender-Mac Learning : Disabled
Locktime : 1000 milliseconds
Retransmit Time : 1000 milliseconds
Reachable Time : 900000 milliseconds (Auto)
Fast Convergence : Off
ARP Global Settings
Max Entries : 12288
Max Pending Entries : 256
Max Proxy Entries : 256
(pacman debug) Leaf1.8 # show fdb
MAC VLAN Name( Tag) Age Flags Port / Virtual Port List
00:00:00:1c:7e:5f untagtenant(4087) 0000 d mi S 1
00:00:00:1c:7e:60 tenant(0010) 0000 s m SXE VR-Default:3.3.3.100
00:00:00:1c:7e:61 untagtenant(4087) 0000 s m SXE VR-Default:3.3.3.100
00:00:00:47:ce:72 tenant(0010) 0000 s m SXE VR-Default:5.5.5.5
00:00:00:47:ce:73 untagtenant(4087) 0000 s m SXE VR-Default:5.5.5.5
00:00:04:d6:4d:6e untagtenant(4087) 0000 d mi 16
00:00:04:d6:4d:6f untagtenant(4087) 0000 d mi S 21
00:00:0b:cb:21:a4 tenant(0010) 0000 d mi 16
00:00:0c:14:88:4b tenant(0010) 0000 d mi S 1
00:00:0c:34:c1:ed tenant(0010) 0000 d mi S 21
00:04:96:9b:b7:c9 trunk1_4(4088) 0000 d mi 7
00:04:96:9c:2d:24 trunk1_3(4089) 0000 d mi 5
00:04:96:9d:42:32 tenant(0010) 0000 s m S 21
00:04:96:9d:42:32 untagtenant(4087) 0000 s m S 21
00:04:96:9d:42:32 trunk1_2(4001) 0000 s m S 21
00:04:96:9d:42:32 isc(4000) 0000 s m S 21
00:04:96:af:9d:1c Default(0001) 0008 d m 33
00:11:88:ff:04:74 tenant(0010) 0000 s m SXE VR-Default:5.5.5.5
00:11:88:ff:04:74 untagtenant(4087) 0000 s m SXE VR-Default:5.5.5.5
Flags : d - Dynamic, s - Static, p - Permanent, n - NetLogin, m - MAC, i - IP,
x - IPX, l - lockdown MAC, L - lockdown-timeout MAC, M- Mirror, B - Egress Blackhole,
b - Ingress Blackhole, v - MAC-Based VLAN, P - Private VLAN, T - VLAN translation,
D - drop packet, h - Hardware Aging, o - IEEE 802.1ah Backbone MAC,
S - Software Controlled Deletion, r - MSRP,
X - VXLAN, Z - OpenFlow, E - EVPN
Total: 19 Static: 10 Perm: 0 Dyn: 9 Dropped: 0 Locked: 0 Locked with Timeout: 0
(Software Update Required) Leaf2.21 # show fdb
00:00:00:1c:7e:5f untagtenant(4088) 0000 d mi S 53
00:00:00:1c:7e:61 untagtenant(4088) 0000 s m SXE VR-Default:3.3.3.100
00:00:00:47:ce:72 tenant(0010) 0000 s mi SXE VR-Default:5.5.5.5
00:00:00:47:ce:73 untagtenant(4088) 0000 s mi SXE VR-Default:5.5.5.5
00:00:04:d6:4d:6e untagtenant(4088) 0000 d mi S 66
00:00:04:d6:4d:6f untagtenant(4088) 0000 d mi 4
00:00:0b:cb:21:a4 tenant(0010) 0000 d mi S 66
00:00:0c:14:88:4b tenant(0010) 0000 d mi S 53
00:00:0c:34:c1:ed tenant(0010) 0000 d mi 4
00:04:96:9b:b7:c9 trunk2_4(4089) 0000 d mi 49
00:04:96:9c:2d:24 trunk2_3(4090) 0000 d mi 57
00:04:96:a3:fb:b0 tenant(0010) 0000 s m S 66
00:04:96:a3:fb:b0 untagtenant(4088) 0000 s m S 66
00:04:96:a3:fb:b0 trunk1_2(4001) 0000 s m S 66
00:04:96:a3:fb:b0 isc(4000) 0000 s m S 66
00:11:88:ff:04:74 untagtenant(4088) 0000 s m SXE VR-Default:5.5.5.5
Total: 18 Static: 10 Perm: 0 Dyn: 8 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
(Software Update Required) Leaf2.22 # show iparp
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 0 NO tenant 10 66
VR-Default 10.1.100.2 00:00:0c:34:c1:ed 31 NO tenant 10 4
VR-Default 10.1.100.5 00:00:0c:14:88:4b 7 NO tenant 10 53
VR-Default 192.168.3.1 00:04:96:9c:2d:24 60 NO trunk2_3 4090 57
VR-Default 192.168.4.1 00:04:96:9b:b7:c9 11 NO trunk2_4 4089 49
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 0 NO untagtenant 4088 66
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 37 NO untagtenant 4088 4
VR-Default 20.1.100.3 00:00:00:1c:7e:61 0 YES untagtenant 4088 VR-Default:3.3.3.100
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 7 NO untagtenant 4088 53
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 YES untagtenant 4088 VR-Default:5.5.5.5
VR-Default 192.168.5.0 00:04:96:a3:fb:b0 60 NO trunk1_2 4001 66
VR-Default 172.16.1.0 00:04:96:a3:fb:b0 60 NO isc 4000 66
Pending Entries : 0
Timeout : 60 minutes ARP Sender-Mac Learning : Disabled
Reachable Time : 2700000 milliseconds (Auto)
ARP Global Settings
Max Entries : 12288
(Software Update Required) Leaf3.23 # show fdb
00:00:00:1c:7e:5f untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:00:00:1c:7e:60 tenant(0010) 0000 s m XE VR-Default:3.3.3.100
00:00:00:1c:7e:61 untagtenant(4090) 0000 s m XE VR-Default:3.3.3.100
00:00:00:47:ce:72 tenant(0010) 0000 d mi 1
00:00:00:47:ce:73 untagtenant(4090) 0000 d mi 1
00:00:04:d6:4d:6e untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:00:04:d6:4d:6f untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:00:0b:cb:21:a4 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:00:0c:14:88:4b tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:00:0c:34:c1:ed tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:04:96:9b:b7:c9 leaf3_trunk2(4093) 0000 d mi 50
00:04:96:9c:2d:24 leaf3_trunk1(4094) 0000 d mi 51
00:04:96:9d:42:32 tenant(0010) 0051 d m X VR-Default:3.3.3.100
00:04:96:9d:42:32 untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
00:04:96:a3:fb:b0 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:04:96:a3:fb:b0 untagtenant(4090) 0000 s m XE VR-Default:1.1.1.200
Total: 16 Static: 11 Perm: 0 Dyn: 5 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
(Software Update Required) Leaf3.24 # show iparp
VR-Default 192.168.6.1 00:04:96:9c:2d:24 20 NO leaf3_trunk1 4094 51
VR-Default 192.168.7.1 00:04:96:9b:b7:c9 20 NO leaf3_trunk2 4093 50
VR-Default 10.1.100.1 00:00:0b:cb:21:a4 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.2 00:00:0c:34:c1:ed 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.5 00:00:0c:14:88:4b 0 YES tenant 10 VR-Default:1.1.1.200
VR-Default 10.1.100.6 00:00:00:47:ce:72 0 NO tenant 10 1
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.3 00:00:00:1c:7e:61 0 YES untagtenant 4090 VR-Default:3.3.3.100
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 0 YES untagtenant 4090 VR-Default:1.1.1.200
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 NO untagtenant 4090 1
Dynamic Entries : 4 Static Entries : 8
Pending Entries : 0
ARP Global Settings
Max Entries : 12288
# show fdb
00:00:00:1c:7e:5f untagtenant(4091) 0000 s m XE VR-Default:1.1.1.200
00:00:00:1c:7e:60 tenant(0010) 0006 d m 33
00:00:00:1c:7e:61 untagtenant(4091) 0006 d m 33
00:00:00:47:ce:72 tenant(0010) 0000 s m XE VR-Default:5.5.5.5
00:00:00:47:ce:73 untagtenant(4091) 0000 s m XE VR-Default:5.5.5.5
00:00:01:23:c7:5f routed(4030) 0000 d mi 33
00:00:04:d6:4d:6e untagtenant(4091) 0000 s m XE VR-Default:1.1.1.200
00:00:04:d6:4d:6f untagtenant(4091) 0000 s m XE VR-Default:1.1.1.200
00:00:5e:00:01:01 tenant(0010) 0000 d m X VR-Default:1.1.1.200
00:00:5e:00:01:01 untagtenant(4091) 0000 d m X VR-Default:1.1.1.200
00:04:96:9d:42:32 trunk2_3(4093) 0000 d mi 105
00:04:96:9d:42:32 tenant(0010) 0000 s m XE VR-Default:1.1.1.200
00:04:96:9d:42:32 untagtenant(4091) 0000 s m XE VR-Default:1.1.1.200
00:04:96:a3:fb:b0 trunk1_3(4094) 0000 d mi 57
00:04:96:a3:fb:b0 untagtenant(4091) 0000 s m XE VR-Default:1.1.1.200
00:11:88:ff:04:74 tenant(0010) 0000 s m XE VR-Default:5.5.5.5
00:11:88:ff:04:74 untagtenant(4091) 0000 s m XE VR-Default:5.5.5.5
00:11:88:ff:04:74 leaf3_trunk1(4088) 0000 d mi 89
Total: 22 Static: 14 Perm: 0 Dyn: 8 Dropped: 0 Locked: 0 Locked with Timeout: 0
FDB Aging time: 300
(pacman debug) Spine1.45 # show iparp
VR-Default 192.168.1.0 00:04:96:a3:fb:b0 20 NO trunk1_3 4094 57
VR-Default 192.168.3.0 00:04:96:9d:42:32 20 NO trunk2_3 4093 105
VR-Default 10.1.100.3 00:00:00:1c:7e:60 1 NO tenant 10 33
VR-Default 10.1.100.100 00:11:88:ff:04:74 0 YES tenant 10 VR-Default:5.5.5.5
VR-Default 20.1.100.1 00:00:04:d6:4d:6e 0 YES untagtenant 4091 VR-Default:1.1.1.200
VR-Default 20.1.100.2 00:00:04:d6:4d:6f 0 YES untagtenant 4091 VR-Default:1.1.1.200
VR-Default 20.1.100.3 00:00:00:1c:7e:61 1 NO untagtenant 4091 33
VR-Default 20.1.100.5 00:00:00:1c:7e:5f 0 YES untagtenant 4091 VR-Default:1.1.1.200
VR-Default 20.1.100.6 00:00:00:47:ce:73 0 YES untagtenant 4091 VR-Default:5.5.5.5
VR-Default 20.1.100.100 00:11:88:ff:04:74 0 YES untagtenant 4091 VR-Default:5.5.5.5
VR-Default 172.16.1.2 00:00:01:23:c7:5f 15 NO routed 4030 33
VR-Default 192.168.6.0 00:11:88:ff:04:74 20 NO leaf3_trunk1 4088 89
Dynamic Entries : 6 Static Entries : 10
Pending Entries : 0
ARP Global Settings
Max Entries : 12288
# configure ip anycast mac 02:e0:52:00:01:00 # configure vlan tenant ipaddress 224.0.0.18/32 # enable ipforwarding broadcast vlan tenant # enable ip anycast vlan tenant
